2001 DR200SE turn signal problems
Hi there,
I bought a 2001 DR200SE a few weeks ago and it was missing a turn signal so I replaced it. Now the right side when turned on just stays on and doesn't blink. The left side does the same but the front left bulb doesn't go on, I think that might just be a bad bulb. Could this be a relay problem?
Thanks,
Maddie
Hi there,
Thanks,
Maddie
The circuit can be cut somewhere make sure all wires are connected and are frayed.
If the blinkers are on solid it would indicate a faulty blinker relay. I recommend buying the shop manual for the DR200SE which I did. I think it’s about $60 and I find it indispensable. I’ve had to work on the carburetor for instance and couldn’t have done it without the shop manual. The same with valve clearance adjustment.
