03 Kx250 bogging
Recently while riding down a trail, my bike suddenly began bogging and not running correctly. It felt as if the ignition was incorrect and was only igniting every 2 or 3 cycles of the piston. It bogged at all speeds in all gears and the only way to keep it running was by quick flicks of the throttle. Constant or no throttle would cause it to die. The piston is not seized and still has great compression. Clogged jet? Bad stater? Broken connections? Any thoughts? I use 92 octane mixed 40:1 with maxima 927 premix.
1 hour ago, Abell3 said:
 maxima 927 premix.
This is part of the problem , castor oil loads the plug up with oil at lower engine speeds and engine temps
have you ever jetted the carb ?
if it is stock it would be way to rich
what temps and elevation do you ride at ?
Pulled the spark plug and its near perfect. Typically ride at less than 50ft above sea level and in temps between 80-95 F here in southern Florida
What jets and needle are in the carb at the moment ?
