2003 KLX125L Rear Shock Swap Help (KX/RM100 shock)
Hello TT, I am currently going to replace the rear shock on my 2003 KLX125L (same thing as a DRZ125L with green plastics) and i would like to know if the KX100 shock bolts right in direct fit on the STOCK swing arm? i have searched around and haven't got a straight forward answer to my question for the stock swinrgarm and i know about the dr_drz thread for his DRZ but he's also using a KX swing arm. Just wanted to know if it's a direct fit besides removing upper chain roller or if there's any machining need done. Thank you.
