XR500R wiring help
hi there, I`m having some issues trying to wire up a 1981 Honda XR500R I bought from a friends Dad. The story goes they bought this bike used and he rode it for a couple years. Then the CDI box crapped out and they took the box off to find a replacement. Fast forward 3 years and its still sitting there not running, with the wiring hanging all over. So I check the bike over and it`s got compression and seems pretty solid. I buy a new replacement CDI box and get to wiring it up. Well this is where the problem starts. The wiring has been mostly stripped out of this bike. No lights at all, just the basics. So the manual shows the alternator has two wires coming off it, but this motor has 5 wires. I googled the motor number and find out its an 1982 that someone put in the 1981 frame. So now I`m totally confused as to what I need to do. My friend and his Dad both said the bike ran with the exact CDI box I bought, so the previous owner had it figured out at some point.
I've added a few pics. The first is the wires coming off the Alt. the 2nd is the wiring for a 1981 and the 3rd is a pic of the motor # showing its an 82. Does anyone know what I need to do to get this running?
@Cory1 First we need to get the proper wiring diagram. That diagram is completely wrong for the engine. I've re-wired 4 different bikes and Honda keeps a similar theme on its wiring. From the wires you have this is my best guess until we see a diagram or you trace the wires into the stator cover and show me that:
Black/Red - most likely the pulse from the stator to CDI to the ignition coil
Pink - Positive Voltage signal that goes to Regulator/rectifier; this is for 12V accessories past the battery
Yellow - negative voltage signal that goes to Reg/Rec; this is for 12V accessories past the battery
Green/Red - typically this is for a neutral indicator light to the dash cluster
White/Yellow - return feedback loop from run/stop switch?!?
Green - GROUND (always)
Black - power typically past the CDI or key switch
yellow & yellow & white + pink run to reg. rec. for lights
green & red - neutral light
only ones you need to worry about are black & red - to cdi
+ pick-up coil wires to cdi - coming out of clutch cover
Edited by S.O.A.N.Z
Updated:
3 minutes ago, ThumperCurtis said:
Black/Red - the pulse from the stator to CDI to the ignition coil
Pink (NOT USED for RUNNING ENGINE) - Positive Voltage signal that goes to Regulator/rectifier; this is for 12V accessories past the battery
Yellow (NOT USED for RUNNING ENGINE) - negative voltage signal that goes to Reg/Rec; this is for 12V accessories past the battery
Green/Red - neutral indicator light to the dash cluster
White/Yellow - Ignition power going through a regulator to the Black side of the Ignition Coil (this is your spark power)
Wow! Thanks guys for the info, that's awesome! I'm going to try and get this running this weekend. I'll let you know how it goes.
