1981 XR200R PULSE GENERATOR ADJUSTMENT
When taking apart the CDI to set the gap I barged right in and took the entire ring out. I was stupid in not paying attention to where the rotation of the ring is. I'm sure it has an impact on the timing. is there a "home" mark of some sort or a good place to start. What are the performance  symptoms of to far clockwise or to far counterclockwise?
I did set the proper gap at 0.012"
Bought it as a literal basket case
Helm Inc.com , $39.95 for the factory manual.
o
can you see where the metal is dirty then clean from ~ 4 o clock to 9 ?
Edited by highmarker
I have an update on the situation. I blued and scribbled a mark then made small adjustment both ways from the mark with a test ride between. I could not sense much difference and I was satisfied with a couple degrees counter clockwise from a full clockwise stop. Rotate clockwise until it stops then back it off a couple degrees.
