Best tire spoons for Drz400?
I am wanting to buy tire spoons with wrenches built into the end to keep on the bike when riding.
What is the general consensus for the best ones to get?
Thanks!
Thanks!
I carry a spare 21" tube (which I can use front/back), a patch kit, a small dual action air pump, CO2, and a set of Motion Pro combos for my CFR250R but this is only for the absolute worst case situation having to deal with a flat when you are in a very remote place extremely far from where you started. For example say 70KM or 40 Miles on really hard technical terrain. If its a logging road see below.
Personally I also carry about 12 super heavy duty zip ties that are about 1/4" wide and start off about 24" long but I cut them down to say 12" so easy to carry in my pack. If you flat and you are relatively close to get back to where you started or the road is easy, you can use say 6 or so to hold the tire to the rim and ride out slowly.
As a suggestion and regardless of your bike (and I do have a 400E) if you do buy combo's, try actually changing a tube with them before you really need to.
DRC Hardware makes about a 9" tire spoon combo wrench to fit a drz rear axle.I still prefer to use their 10 1/2" dedicated tire spoons though.Just remember one thing when selecting tire spoons,always get at least 3 of the same.A MotionPro beady buddy or two also comes in very handy to have as a third hand to hold the bead down.
And if you want to get crafty, you can mount a tire spoon to the left side of swing arm. Where the chain guard goes.
I use the Motion Pro T-6 Combo Lever. Can't say if they are the best because I haven't used other brands (I bet the Tusk version are good and will save you a few bucks) but they have worked when I needed them.
+1 for the Tusk set. I have their regular spoons as well and have been very happy.
What rim protectors to you guys use? I want to start saving some cash and change my own tires but don't want to scratch my black rims.
i think mine are motion pro, theyre blue anyway .. theyve held up well to about 8 or so changes .. theres a last bit on every tire where you cant really use them, so i suggest always  lots of lube and get mean with it and always mount/dismount from the left side which is less visible, you'll wind up with small marks on the edge, comes with the territory .. a sharpy to touch them up does the trick ..
3M makes a scotch brite polishing wheel, takes out the machine marks on the spoon faces.  Same wheel is handy to smooth the sharp corners from the gear shift lever.
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
