Supermoto rims
hi i have a 2017 wr450f. I shall now put on supermoto rims. These should fit on a yzf450. I have a speedometer. How do I do the easiest to make it fit with the speedometer. Is it going? if I not i have to buy type trail tec speedometer. What other parts do I need then?
Not sure you will be able to use the standard speedo drive as the circumference is smaller on a 17” wheel.
This will also cause your odometer to increase faster as your speedo isn’t reading true.
i would just buy a cheap electronic speedo or buy a trail Tech unit.
there are also GPS based speedometers but I’m not sure how reliable they are.
GPS speedo.... works with any size wheel, everywhere except under ground
you could use your phone, and have your mp3 available on the bars too
been doing this for years
My biggest problems. What part I need for the rim to fit.
Spacers ? Axel?
Please dont write if you aren't 100% sure
Spacers ? Axel?
Think you might be better asking in the Supermoto section of this site,also try a forum called Supermoto Junkie.
