1995 XR 100 suspension swap (from a 1990 CR-M 80)
Hi to all,
A couple of weeks ago I bought a 1995 XR 100. Engine and Frame were decent, everything else was in bad condition.
I started fitting a CR-M Suspension (european street legal version of a CR 80. Engine is completely different, suspension is almost the same, stretched and revalved for teenagers). Front end is done with some fabrication, but I am really buzzled with the rear end. Swingarm is already fitted in with some minor grinding. I am thinkin on giong to a linkageless rear...and I would really like to keep the original airbox.
Can I use the stock CR 80 Shock? I´ve seen that KTM 65 is the normal choice....but here in Chile those are hard to find.
Any advice?
Thanks
Some pics of mi progress
Awesome job so far.  The only other swap I've seen, was a guy on here four or five years ago.  They did post pics, try a search.  A lot of us, put the motor in the CR Chassis (1996 and up).
Cool project.  To answer the shock question....no.  a link vs linkageless shock is different.  Different travel, valving and typically some sort of progressive spring.
Well... I found a Shock from a chinese pit bike that is supposed to work linkageless...now I´ve got sort of a roller. Now changing the upper mount to get a decent position....Not so bad so far. Photos soon.
Well, lots of work and no time to post, but so far I have a fully functional (yet ugly) XR 100 with improved suspension, wheels and brakes. I really love the way it handles. Engine seems to be in a great shape.
some pictures...
I think the main job is done....
I just have to make her look pretty....or maybe keep the MadMax Style :)
Cleaning an polishing is were I will start from...but still haven´t decided if I should keep the '95 look or go for an update.
Opinions?
