2005 KX85 Base Gasket Question
I’m building a 2005 kx 85 engine. Is it safe to run without a base gasket and just use a high temp sealant? Or is the squish tolerance tight to start? Thanks!
Just get a gasket.
Just get a gasket.
That doesn’t newer my question
What are you trying to accomplish by not using a base gasket?
Getting it running that’s all we don’t have
Technically you would have to measure the clearance to see if it was too tight.
The squish cane to 1mm with no gasket
