Fuel Screw O-Ring
Does anyone have a suitable sub for the o-ring used in the fuel screw of the stock carb? I seem to go through them frequently most likely due to the ethanol gas we have here in Hawaii. Honda only seems to sell it as part of a gasket set. All I need is that o-ring, not the entire gasket set.
Jetsrus has a variety of o-rings listed, but not specifically for the 230F. I have an inquiry in to them so hopefully they carry something that will fit/ work. If anyone has the dimensions or part number of the original o-ring that would be of tremendous help.
http://www.jetsrus.com/parts/orings.html
http://www.jetsrus.com/mixture_screw/mixture_screw.html#hondadirt
I've just ordered some o-rings from jetrus after doing some measurements of the old crusty ones that came out of the carb in the past. I'll update this thread once received and can confirm what size actually works in the stock carb and the actual dimensions of the o-rings for future reference.
