TPS voltage yz450f 2015
Yes, all the Keihin systems use a TPS voltage of around .55 volts. The small range of voltage is for advancing the map a bit.
You must apply voltage to the TPS to make the measurement.
http://www.yfzcentral.com/forum/86-yfzr-x-powertrain/253185-adjusting-tps.html
Great link. Thanks
How many amper do I need for this?
I removed my tps not knowing you actually need the fi diagnostic tool to set it correctly.
Is there any given standard voltage i can adjust it to? Read in an old thread 0.65 V. Can anyone verify?
Manual only refers to adjust using the fi tool.
