I bought a 2001 yz 125 for $700. Plan to tear it down and see what's going on inside this baby. Depending on how bad the engine is I'll ether keep it and have it be my race bike for next season or sell it and try to make a couple hundred and get a little better one. I bought the bike like this with a box of parts along with it.
Yeah I did a little but it's fine with me because most of the bikes like this that run sell for around $1,400 in my area. Plus it makes things easy when I have a motorcycle shop to use. I like working on bikes and will have something to do when I get bored this winter. I can get this bike to look and run like new without spending much money.
Edited by Josh the squash
  • Like 3
I got the bike to start today. The wudruff key that holds the flywheel was broken so I made a makeshift one out of aluminium real quick just to see if the bike ran. The bike fired up 3rd kick. when I took the engine out and seen that the piston has been seized but the previous owner just threw a new ring on it. Lololol figured this would happen. Luckily it has a sleeve in it so getting it repaired is much less $$$. I felt the rod, and surprisingly it had no up and down play in it and the flywheel side of the crank didn't have any play so there could be a chance the crank bearings aren't trash. Next is to inspect the clutch.
On November 4, 2017 at 10:01 PM, William1 said:
No offense but you over paid. A good assembled runner is a $850.00 bike in spring, a $700.00 bike off season in 2017.
Friendly reminder just to keep in mind the average price for a bike will be different depending where someone lives. For example an 01 yz125 where I am would be about 1200-1400. As for the op keep us updated with what you do with the bike, always fun to follow a rebuild thread!
We are working in USD, not CDN. Also, bike was a non-runner.
Yeah I realize, I just meant that for me a 5 hour drive means the difference of $4000 for a 2015 yz250f compared to $5500 for a 2014. So I was only suggesting that prices can vary largely even in the same country or state. Sorry for the confusion haha.
Good for you man!  Looking great!   Your lucky those crank bearings are good!  I'm going trough a full engine rebuild on my 01 cr125
That will be a great race bike someday (soon) at the rate your going!  Whereabouts are you in Michigan?  Im close to Windsor Ontario...near the border.
Btw that swing arm looks like its for a newer bike...What do you think?
Thanks! The swingarm could be off of a newer bike but I think its the original but I could be wrong.  the previous owner said he built the bike from the frame up so some of the parts could be off of newer or older bikes. The swingarm cleaned up very nicely. Good luck on your cr125. I will be cleaning up the rear wheel plus greasing the wheel bearings, truing the wheel and will be posting pictures of that tonight.
Awesome sounds great!
Mind if i post a few pictures of my project build cr125?  I understand sometimes its a pain if someone else uses your topic to post their junk.😁  Let me know thx
Yeah that's fine I'd like to see it
Ok...I have a lot of work to do lol!  I ordered a whole new engine rebuild kit, GPI oversized rads, new back tire, already did all the bearings, new air filter, and i ordered a new pro circuit 304 silencer to go with my pc pipe.  I will post more pictures when i am done!
  • Like 2
Cleaned up the back wheel and the last person who tried to grease the wheel bearings put grease all over but never actually took the seal off so none of the grease was on the bearings😂. I get them packed and the wheel looking nice. And also cleaned off the pipe and silencer.
  • Like 2
Nice!  Thorough cleaning job man!   Keep posting pictures!  Have you ever had the pro circuit 304 shorty?
i have not, from what i have heard they are perfect on a 125.
Well I have some bad news, but everything is fixable. The meat head that sold me this bike lied and the bike is really a 1999. I looked it the engine and frame numbers. Going to probably need a new crank, which I was ready to do anyways and I found a bunch of metal shaving from the clutch case where a bolt had came lose and started cutting away at the aluminum. I will be able to fix everything and at least the clutch and transmission are good.
Ohh, that's too bad. How did it come loose?  I guess the idiot in the engine who tried to rebuild it didn't like tightening things down?  The guy who had done mine put lock tight on every single bolt.  I'm like hitting the wrench that's on 8mm bolts with by palm trying to losen them!  One extreme to the other! lol
Here is what my bike looked like about 3 months ago...When i'm done this overhaul i think (hope) it will look/perform even better;(:
IMG_5916.jpg.f0d9cf9f4839770db31d2c5e56947be6.jpgIMG_5909.jpg.bcfde11dc8ba6feb2cf908bc29bb8ee6.jpg
  My left case is getting welded right now. Case saver chain guard thingy snapped off along with the mounting aluminum.  Thankfully my brother had a 01 cr125 as well and same problem with his; he kept the guard so i can use it now! :applause:   Also my drain bolt is stripped so i will have to drill/rethread that as well.   IMG_6047.jpg.0b0234c9b228c6120b57aba53d159a22.jpg
These old bikes ah?  I guess its kind of fun and a good experience but it gets expensive ordering so many parts!
Anyway, good look with the rebuild and keep us informed!
Cheers!
Edited by Slicing-Air
