O-ring vs X-ring chain
I am considèrent either a DID  X-ring or an O ring replacement drive chain and the o ring is much cheaper
A-will the O-ring  fit a sxf 450 2017 without rubbing on the cases ?
B-other than additional friction with the ô-ring, what am i missing?
tks,
Nicolas
X ring has 2 wipers where O has 1 contact patch. 1 wiper to keep grease in, the other to keep crud out. X supposed to be longer life. Fast way .050" spacer behind drive sprocket for clearance. I think some use some type of automotive valve spring shim for same result.
If you get the did narrow X ring they fit fine
I can tell you that the DID VT2 that comes on the ktm XC line is the most stout chain I've ever used and at $83 bucks it's a no brainer. I order those chains from the ktm oem section for all of my bike no matter the brand. I just installed one on my YZ450F
And yes it will clear the cases on 450sxf
Ok Tks all for the reply ,will go  xring vt2
