IM DONE LISTENING TO MY KICKSTARTER SLAP ON MY 2T PIPE
Fo many years ive tolerated the sound of my kickstarter slapping against the top of my 2 stroke pipe. I can no longer take this. Here´s the issue explained.
Somewhere along the life of my 300 xc-w I hit the pipe on some log or rock and ever since then the pipe and tip of kickstarter have been in slight contact. When I rev or ride the bike the point of the kickstarter makes the most annoying "ching" on the pipe.
Please help me fix this. And no, im not going to buy a new pipe. (Mine is perfect as is)
Move the kickstarter down one notch on the shaft.
Push a rubber heater hose over kick pedal. Make sure it's a tight fit, might have to take kicker off & use dead blow hammer. Done this lots in the past.
step1.Remove the pipe, then push extraneous 300xcw out of the way.
step 2. Purchase a brand new 2018 300xcw and remove stock pipe.
step 3. attach your old pipe to this brand new bike.....and off you go!
Joe
  • Like 3
Note where kicker touches on pipe. Dent pipe out of the way there with a heavy object and a block of wood.
On car forums they call ot "clearancing" or "massaging".
You now owe me a beer.
  • Like 2
I'm curious if the OP has a snug fitting carbon fiber pipe guard.  I've found that they protect the pipe from dents very well, but unfortunately the whole pipe bends when you crash. His pipe is probably like mine--nary a dent--but the whole thing is just displaced enough to contact the kickstarter.
I would just "clearance" the pipe as described above.  It just takes a smidge.
Sooner or later I'll smash my pipe good, and future pipes will be protected with aluminum guards like my other bikes.  They have some crush space to absorb energy.
I dont run a guard.I haven't totalled my new pipe yet but it looks like a golf ball.
Surprisingly it seals well at the moment. I think I bent it straight again.
ding ding ding we got a winner!!!!!
Kind of
I've tried everything. I don't know wtf. It still finds a spot to rattle. Plus my exhaust takes a beating and is always bent or jammed differently
I've used a little high temp silicone to make a rest for the kickstart so it won't rattle in the past. Easy and cheap gotta replace it every so often.
Kind of
Have you take your pipe off since you smacked it? Big possibility that it is eating your exhaust flange. Just sayingm you should check it out...
Ugh. I looked. This is a brand new pipe that's already destroyed. Even with a guard it has a giant dent. And it's also bent so bad that jts wanting to pop out of the exhaust flange. First pipe got super bent. I straightened it so many times it finally broke. This new pipe is already mangled and needing its first bend back. This sucks. Looks like I'll order the pipe plug dent kit. And bend it back straight. And maybe rebuild kick starter. And and and and...
IMG_3365.thumb.jpg.21257ab4030436a90922fb81330e0e75.jpgIMG_3366.thumb.jpg.6fae022424f909e165994f0c0585eabd.jpg
That pipe is tweaked a bit. :) Try pacific pipe repair. Note that pipes on the two smoke should be regarded as a consumable because you'll be whacking it many more times. Count on it. Shop for used OEM take offs on eBay and just rotate a stock of 3 or so pipes.
  • Like 2
consumable is right. ive had that pipe for like 6 rides!!!!!
with the amount that I go through them, I gotta fix em myself.  bending them in the vice is easy.  I just gotta bite the $60 plug kit to deal with dents... not that they bug me/affect performance.
https://www.frankmxparts.com/epages/62910900.sf/en_US/?ObjectPath=/Shops/62910900/Products/1450
Edited by cdf450
I'm trying to determine if that is a Jack Pine, Lodgepole Pine or Black Spruce stem in there?
http://www.insideeducation.ca/wp-content/uploads/2014/10/TreeShrub.pdf
