Bryan Bosch
Hope that all Optima batteries don't suck!
18 posts in this topic
In May, I needed a new battery for my Jeep TJ and I got sucked into the "Optima batteries are the best of the best!" talk on-line; people seem to swear by them. Got in my Jeep today and nothing... Pull out the volt meter, 4.6v. No lights left on and about the only creature comfort is a stereo that has no power when the key is in the off position and when removed.
Now, I know that nothing is perfect, but I'll admit, I'm a little sour on the brand today. When I called them about warranty (purchased it via Amazon), the lady on the phone was very indifferent, never once apologized on behalf of the brand for the failure, and made quick work of telling me that's it's not their responsibility, but Amazon's. And, even ok with that, just the indifferent attitude that is lingering. Pretty sure that caring about your brand is free.
Anyone else had an Optima battery (red top) discharge for no apparent reason? I've never had this happen with any brand of battery in my 30+ years of driving. I thought about a possible draw, but again, no real electronic accessories and with LED headlights, trust me, in the light of day, you can't miss they are on.
So, not sure if I just got a lemon, but I just had higher hopes for such a premium battery. I certainly expected a better attitude from the mfr. 1st world problems... ;)
I've only had 1 optima battery, and it was a yellow top and I bought it in 2003ish.  But I took that truck to a lot of bonfires and left the radio running for hours and it was still going strong 3 years later when I sold the truck.
Never owned one but I read a very thorough comparison of several major brands in a mag once and they all came out about the same performance wise. No reason to spend the big bucks for an Optima was the consensus.
1 person likes this
Did you have the battery charged and then tested? A bad/leaky diode in the alternator can cause the battery to drain overnight.
2 people like this
I fell for the hype once and bought a red top optima and it sucked. Was in an 81 Chevy pickup super short life span wouldn't keep a charge had a brand new bigger alternator. Bought a wal mart everstart max I think and it was great for a few years.
Optima batteries were excellent before the manufacturing left the USA for mexico. I install high end batteries at my shop all the time. The only high end battery worth the money is odyssey. It's ridiculous the stuff you can do to them and they just keep on going.
They cost about 30% more than a comparable optima, but they are 100% worth it. Still made in the USA too
I tested for a draw and found that I have a .15A draw or 150mA. My understanding is that it shouldn't be more than 50Ma? So, on the smaller side, something that could draw the battery down if not driven a lot. And, i don't... It's not a daily driver. So, off to pull fuses one by one to see if affects the draw. Thx for the suggestion. Never encountered this before.
1 person likes this
My ‘06 Silverado still has the original battery.  A small solar panel keeps it fully charged.  It’s just now showing signs of weakness.
That might be a record. I bet if you sent a nice letter to the PR dept of the mfg telling them how impressed you are they would send you a voucher for a new one.  Don't ask for one, just pump them up and see what happens.
2 people like this
I didn’t add the Shipwrecks twenty-dollar solar panel until the battery was at least five years old.  I think twenty years is not out of the question.  You just need to keep the battery from sulphating.
I also think the panel I have could be a bit larger but if you go too big, it can fry the battery without a charge controller.
10 hours ago, YHGEORGE said:
Where is it mounted?
In the back window.  Truck is usually parked with back window facing South.  Panel just plugs into the cigar lighter.
I went through 2 yellow tops in almost 3 year. Had my Costco battery in my Toyota for 10 years before it went bad.
Depending on the size AGM battery you need Trojan Batteries will last a along time. But the group sizes are limited to 24,27,31 and GC12.
Had a Optima Red in my 1994 Jeep Cherokee for 13 years, still in there when I sold it.  Didn't know production moved south of the border.  That may be the issue.....
I have an optima Red Tops in my dodge diesel, and they have been getting it DONEl, no bad stories here, over 5 years old.
Hmm, I use them on my race truck and fortunately no issues yet. My truck has a lot of electrical systems, tons of lights, multiple radios, GPS systems, forced air systems for pilot and co-driver and a water system for the driver and co-driver. I also have a hook up to keep electronics charged in the event of a truck failure out in the desert. Keeps an iridium sat phone, cell phones, and GPS devices and a backup battery for electronics charged at all times.
So my question is was this a brand new battery? If not how long had it sat? And why did you replace your previous one?
Bryan--did you charge up/top off the new battery after you installed it?  I just bought new AGM--Absorbed Glass Mat--Sears Diehard Gold battery Size 34 for my '98 Jeep ZJ Grand Cherokee and installed myself.  Charged it on my Battery Tender trickle charger over half a day before full-charge solid green light came on.
I was replacing a Sears "Platinum Diehard AGM" which apparently is no longer available; that battery lasted some 12 years and did not leak acid gasses through terminals--old connectors were the cleanest I have ever seen when replacing a battery in my over 50 years of driving/maintaining.
Edited by BSAVictor
