Drz400 2001 temperamental...
Some days I go out , fuel on, choke on, kick twice, bikes purring, other days, like today, I am better off going to the gym for legs day as it wrecks me. The &%$#@! of a thing is more temperamental than a drunk woman.
I don't know much about bikes but since I got it, replaced spark plug and bled brakes (not that brakes have anything to do with starting)
Once its hot, starts easy enough but still sometimes its a maggot that I want to light on fire.
Am finding TDC before kicking, using the decomp lever to do so..
Hot start when its hot ..
Choke when its cold
Its a 2001 drz400 not an E or S
Stock
Am getting tired of this bikes antics, am contemplating selling it and investing in a newer bike. But if it won't start , it wouldn't be worth more than a handful of pennies..
Hard cold start is usually tight valves.
https://thumpertalk.com/forums/topic/718276-drz-valve-clearance-check-and-adjustment-plus-cam-timing/
Figure out which carb you have, either Mikuni BSR36 or Keihin FCR39.  Take a look at this spread sheet, tabs at bottom for your carb/exhaust.
https://docs.google.com/spreadsheets/d/1HNSB3DrqJqHTInjVDKKS4HNSHZPbdK0ElbfNI5HxuZg/edit?hl=en#gid=1172546203
See if these suggestions help.
Odd, those are easiest type to get their motors running.
The bike is not had to start by nature. You have an underlying issue. Valves, air leaks, dirty/ worn carburetor, low compression are just a couple possibilities.
