Crf450r carb on a 05 trx450r
On 11/10/2017 at 10:42 PM, Dieselbeast90 said:
I have an 05 trx450r with the stock carb. I want to swap for an fcr. I was wondering if someone can tell me exactly what i need when swapping an 05 cr450r fcr carb onto my quad. I am not going to modify or go crazy just a simple carb swap.
Go to TRX450R.org You'll get all the info you'll ever need. I'll try to get you going in the right direction.
1) You need one of these Noss Adapters. You epoxy it to the carb.
2) You'll need to rewire the TPS. The connector plug on the CRF won't fit the TRX.
3) If you are going to use the Hot Start, you'll need to use the cable from the CRF.
