Broke off Rear Rotor Bolt
I managed to snap one of the bolts flush with the hub when installing a new rotor. Its in there with blue loctite. I've never used an easyout.  ITs an M6 bolt but not sure which easyout to use.  Suggestions please.
Yeah, my neighbour is a big time boat/tractor mechanic and he gives us a big hand when this kind of thing happens.  One of us broke a front sprocket bolt right off flush with the sprocket the other day and we used a high quality extractor to get it out.  About the only way imo.  Go ahead and search youtube for a "hack" but i doubt you will find one.  Good luck!
Thanks soanz and slicing. Picked up an extractor kit for $5 at lowes. Worked fine.
6 hours ago, shredmasterz said:
I would first heat it up with a heat gun or carefully with a torch  to release the Loctite.
Thanks, yes I used a soldering gun (not my idea, read it somewhere) and held it on the the bolt for about 5 mins.
good to hear, I have a bolt that is broken off in my sons CRF 150 that I will have to tackle at some point.  Nothing leaking now so until I pull that side of the case apart its staying put.
Nickerkx,  FYI, I bought the Irwin kit.  Comes with a drill bit and extractor.  The bit was horrid.  Lost its edge with one rotation.  Have a good bit ready.  The extractor worked fine.  Good luck.
