Harbor freight tools to help with the yz build.
Just got my swingarm bearings and waiting for linkage bearings to get here Monday.
I went today to get a press. I settled on the 20 ton from harbor freight. Had a coupon so it was like $144.
Anyone else have the press and is it holding up?
I just removed the swingarm bearings with it.
One side pressed right out. The other took some work but it did come out.
So far satisfied with the press.
  • Like 3
Following this! Thought about getting one for my swing arm and linkage... but ended up having a local shop do them last week since I wasn’t sure .. still contemplating lol
I've had good and bad luck with them but mostly just use them for low use items or to modify for specialty jobs.
No press needed, I just use my bench vise and assorted sockets from HF. A little heat on the swing/links (I mean LITTLE) and they just push right out like soft serve ice cream.
  • Like 5
I've always used vice and or c clamps
This was much easier. Took me a few tries at first figuring technique but was worth the money.
I'll clean all surfaces and put n the swingarm bearing kit I have.
Linkage bearings will be here Monday or Tuesday.
  • Like 4
I don't think I have ever seen bearings that trashed. But then again, this is not Michigan.
  • Like 2
I’ve had their 12 ton version for about 10 years now and it’s still going strong. Use it all the time. Originally bought it to replace the bearings in my snowmobile bogey wheels.
Rob
Edited by rdlsz24
  • Like 2
Whoo!
  • Like 3
Here's one of the front wheel bearings from my project YZ250F
I've never used a press and for $144 I'm probably not ever going to.
Never could understand why Yamaha OEM bearings are not sealed...
To each his own Willy... All I know is it took one third the time and not even half the effort.
I do 8-10 bikes a year....so it should time save lots of time....and time is money.
I feel it may come in handy for alot of projects.
  • Like 3
Ah, a lil grease on those badboys and they'll be good for another race!
Vice works good. The one time I couldn't figure out why the bearing wouldn't come out, and why I was cranking on the vice so hard.
Turns out I left a washer in the linkage and was fighting aluminum. Maybe I best stick to the vice or I would bust a lot of aluminum.
