What spark plug is everyone using 08 crf250r?
Parts Pit Stop microfiche lists either an NGK 8 or 9 heat range plugs for that application,
the CRis one heat range hotter than recommended. (NGK codes = the higher the number, the cooler the heat range)
Inspect it closely with a magnifying glass under a light for signs of pre-ignition,
like 'fusion' between the center electrode and insulator and/or tiny shiny metallic specks embedded in the surfaces.
Using that #7 plug under heavy engine load, running bad fuel (low octane) or with lean carb settings, could be very problematic.
Edited by mlatour
