Pin found at drain plug 1986 xl350r
Not sure which forum to ask but I need some help identifying. Bike runs fine. Head rebuilt about 30 hrs ago. This pin and a small washer too big to drop out. This is the Canadian model same as 84,85 xl350r. Pin is about 1 inch x 1/8
Will check the decompressor. Could be the dowel
yep looks like the decompressor stop pin
haha. At last years inspection it probably loosely dropped down the chain galley as I lifted cam cover. If I saw the empty hole I would suspect it was an oil passage for decompressor. 😱
repair is done 👍
youre lucky it made its way to the drain plug - could have been catastrophic
