Clutch Slave Cylinder
I have an 2006CRF250X and I want to change the clutch cable mounting over to the R model. I have the cable routed and the R bracket mounted on the left side of the motor when sitting on it.  I do not know how to rotate the slave cylinder around to accommodate the R position for the cable to connect to. It still has the electric starter on it to, I figure it will be close to the actuator arm. Thanks for the help.
