Preparing DRZ400E for a GPS based event
Hey all! so my DRZ now seems to be good... it had a hot start issue which blew my head and patience... but now hopefully its fixed (changed pickup coil).. So now i need to prepare it for a 3 day GPS based event.. here is a list of things i think i need to do.
-longer gearing- now its 13-50 and it is too low for open dirt roads. dont know what gearing to use but thinking about 14-47 or something like that.
-phone holder- will a bycicle holder work?
-phone USB charger- can i use one from a car ? charger is 12V 1.0 Ampere... will the stator hold that, and a little led light to reinforce the high beam?
-changing rear tire- got here a brand new knobby tire, 120-100-18..
-tuning the clutch as the lever is catching too close from the handlebar grip and cant "feather the clutch" with just 2 fingers (need to use all fingers to the clutch disengage)
Finnaly, sorry for my bad english, and thank you for reading!!
Without knowing where you are riding making a gearing recommendation isn't really possible, but I haven't really found a need for gearing lower than 15/47 in the deserts and mountains around me.
I don't mount my phone to my motorcycle but make sure whatever you choose is tuff enough to withstand a crash.
The stator can handle that, but USB chargers often cannot handle the vibrations and dust.
Edited by ptgarcia
I run 14/47 and its a good compromise for technical dirt and street riding.
the stock headlight pulls a lot more current than a phone charging.
14/47 is fine.
clean your air filter
