• Announcements
    • Bryan Bosch
      JUST IN!   07/18/2018
      Video: 2019 Yamaha YZ250F Features & Benefits
gaortiz
MY2018 Beta 500 RR-S Thread
62 posts in this topic
11 hours ago, GBZ18RR-500 said:
So will the AXP skid plate for the 480 RR fit  the 2018 rr-s 500?  I want to confirm before I order.
Yes it bolts right on!
After trying and failing for a while to get mine to snap onto that rear frame using the hooks, I finally shaved a bit of the (brake side) hook back with a razor. Now it fits better up in there and snaps on tightly with a firm shove - only takes a min to get on/off. I’m not using the forward facing hook, doesn’t seem needed to me.
1 person likes this
On 11/18/2017 at 3:53 PM, 4Kracing said:
You already have a violation with your flush mount rear turn signals so what's the difference.  I will be installing mine on the number plate and if I get a fixit ticket then I will deal with it.  I don't plan on riding the road enough to worry about it.
I know guys who have had those hand guards and their lights did not last long.  It's not so much crashing as it is hitting bush and branches and whatever else that does them in.  Aside from all that your bike is beautiful!:thumbsup:
Man Cali must suck. Here in Indiana flush mounts are fine, I have some bikes without mirrors but end up using little bicycle fold up cheapies. The cops are way cooler out this way..
2 people like this
I will be pressing my luck and installing those tusk flush mounts tomorrow. Even though im in California I'm not on the road enough to worry.
Edited by GBZ18RR-500
2 people like this
I'm off road most of the time and the only time a cop is going to be giving you any issues if you're acting like an idiot.
3 people like this
Well here is my setup after removing that huge ugly setup the bike came with. I cut out the old plate mount in the shape of the upper and put it back underneath so the wires are still hidden.
3 people like this
I’ve been running flush mounted turn signals on my Beta in Northern California for 3 years now without issue. They’re brighter than the silly OEM stuff.
I was hassled years ago on my old street legal crf450x, till I showed him the brightness of the same type of flush mount turn signals. Told him the stock stuff got ripped off in the dirt.....
True...
Has anyone put the fmf pipe on their 500.  I was wondering if you need to flash the ECU in order for the bike to run properly with the pipe. The dealer told me i do not but I question their knowledge on the topic.  Any help would be appreciated.
2 people like this
Yes, the dealer will have an FMF map to flash the ECU with. Sounds like you need a new dealer.
1 person likes this
That's what I figured. Luckily I can check with my local dealer. I bought it in Simi Valley because they had the best deal. They flashed my friends husky so I'm sure they can do mine.
Started having issues with the bike last weekend. Anywhere between half and full throttle power would cut out almost as if it wasn't getting fuel. This happened intermittently the first few hours I got the bike but wasn't consistent. So I took it into the dealer and the computer showed a code for low circuit voltage fuel pump. New fuel pump and regulator on order. Funny thing is a friend of mine who bought his '18 390 about a week after mine(I was one of the first deliveries in California) had his fuel pump also go bad and brought his bike into the shop the same day. He also has been having intermittent problems since delivery. Maybe there was a bad batch of fuel pumps? My bike is on the lift and his is in the foreground.
1 person likes this
My 18 390 had a bad connection to the ECU creating a loose and "open" circuit, fried the ecu and gave the low voltage fuel pump warning.  Might be something to look into.  Mine was fixed under warranty and all has been good since.  I believe the fuel pump and associated parts were replaced at the same time.
TR
3 people like this
TR
I was having issues around 75% to full throttle with it feeling like it wasn't getting gas. Were you having those issues?
1 person likes this
I never even had and issue.  Rode it out of the garage one day on my third week of ownership and the engine light came on.  It seemed to run fine, but I turned around and went home.  Looked the connections over, didn't find a thing.  Took it in under warranty the next day.  Took them a while to figure it out, but they finally did.
2 people like this
Update 2: It's not the fuel pump. My gas tank with the fuel pump in it was placed on another Beta and that bike ran fine. Diagnosis pending.
Time to check the ECU, sounds very similar to my issue.  The tech replaced my ecu with one off of his bike and it fried his too, then he found the jiggly open connection and Beta sent a whole new harness and fuel set up.
TR
1 person likes this
Got gold valves front and rear, bladder kit, springs, and micro polish the tubes and shock shaft.
Great looking bike.
I especially like the tail clean up.
1 person likes this
