If I order p/n 12710-29F00 will I get the original "E" intake camshaft?
If I order p/n 12710-29F00 will I get the original "E" intake camshaft?  Assuming I can find one?  I want an upgraded intake can for my DRZ400S.   I know about the Stage 2 hotcams, but would really like to get my hands on an original "E" intake cam. Thanks in advance.👍
yes thats the OEM p/n - assuming yours is one of these
Suzuki Motorcycle 2000 DR-Z400 CAM SHAFT/VALVE
Suzuki Motorcycle 2000 DR-Z400E CAM SHAFT/VALVE
Suzuki Motorcycle 2001 DR-Z400 CAM SHAFT/VALVE
Suzuki Motorcycle 2001 DR-Z400E CAM SHAFT/VALVE
Suzuki Motorcycle 2002 DR-Z400E CAM SHAFT/VALVE
Suzuki Motorcycle 2002 DR-Z400 CAM SHAFT/VALVE
Suzuki Motorcycle 2003 DR-Z400 CAM SHAFT/VALVE
Suzuki Motorcycle 2003 DR-Z400E CAM SHAFT/VALVE
Suzuki Motorcycle 2004 DR-Z400E CAM SHAFT/VALVE
Suzuki Motorcycle 2004 DR-Z400 CAM SHAFT/VALVE
Suzuki Motorcycle 2005 DR-Z400E CAMSHAFT + VALVE
Suzuki Motorcycle 2006 DR-Z400E CAMSHAFT + VALVE
Suzuki Motorcycle 2007 DR-Z400E CAMSHAFT + VALVE
I orderd one intake 2 weeks ago , dealer said 2 to 3 weeks , will let you know , if you can wait .
I see a problem here.  In most cases the OEM will supersede an old PN w a new PN so even if you order an old PN you receive the new part.  I dont recall what year the E was nuetered but you may just receive the new PN despite ordering the old PN....if you can find some NOS (new old stock parts) that are labeled w the correct PN you should be GTG
habs please keep us posted on the outcome of your purchase. If there is a provided spec sheet that lists the lift/duration/LC can you let us know what you receive (I think we're looking for 8.90/260/116, there should also be the letter "A" on the end of the gear portion of the camshaft near the center, you will also most likely see the numbers 1,2,3 and 29F, the letter in the center is the most important, it could be A,B,(C),D,E from all that I have read) Thanks in advance.
ohiodrz400sm please message me. I tried to message you but it looks like you are not accepting messages. Thank you.
the search continues....
It s here , IN E cam .
  • Like 5
I did not check but the A on the shaft (picture) confirm it’s a genuine E cam . Cam is already installed .
