XR250 Clymer Manual spec check from another source please
As noted in another post my Clymer manual for my XR250 on page 74 states the compression should be :-
XR200, 1981-1982 XR250R,XL350R      199psi
XR250, 1984-on XR250R                     192psi
All other models                                 175psi
this isn't right is it. Does someone have the correct numbers please for a 1991 XR250R
Also, now its got me wondering about the valve clearance which have always seemed tiny to me:-
Intake - all models                    .05mm (.002 in)
Exhaust                                   .08mm (.003 in)
Can someone verify those please.
so consensus is that the range is 192-199 psi. But why are  the replacement pistons listed as 10.5 CR i wonder
https://www.ebay.co.uk/itm/Wiseco-Piston-Kit-Honda-XR250-86-04-74mm/321573630863?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
I guess the actual resulting compression is reliant upon other factors other than piston so maybe quoting it against a piston includes the assumption the barrel/jug and head are standard.
Yea there definitely are other  factors, one of the biggest being the cam profile and how much overlap is ground into it. That's why there sometimes different specs listed for static compression vs dynamic compression ratios.
> And compression ratios(ie 10:1) and cylinder pressures (psi) are related but very seperate factors
i think i unerstand - seems odd to quote a calculated figure, would be better for Clymer to give an indication of what should be measured.
Mind you the whole chapter is a bit generic as it goes on about checking cylinder and comparing values, and there is no mention of disconnecting the decomp cable.
Only way you will get valuable compression info is by measuring it with the exact same compression tester over time, if it running good starts easy and doesn't smoke test it. Test it again after 50 hours and see if it is any different. Do disable the Kickstarter decompress or stuff when testing.
