Disk conversion and the brake cylinder using a 650L swingarm on XR600
Looking for help from the guys that have put the 650L swingarm onto the 600R. I have what I believe to be a good pattern for the bracket, but would like everyone to put eyes on it and let me know what you think. Will this work? I have a sheet of 1/4 aluminum that should be rigid enough. What I'm really worried about is the angle of the cylinder.. I know the actuator has movement, but does that angle cause any issues that we are aware of???
Edited by Tmosely1
Here is mine using xr650l pedal and yz450 2009 master cylinder it uses a reservoir that's built in :) no separate  hose and crap. You can see with the position of the pedal requires that the master cyl.stands up a little straighter than you have it now.
