Scored some used real "E" cams, direct drop in right?
Just looking for confirmation as I have researched this a bit.
Basically the only other thing I need (at least on hand) is a shim kit, there is not need to change valve springs and such correct?
Plan is CVK40, E-Cams, maybe Athena 434, "E" CDI to take advantage of the extended power band of the cams.
Everything in the head is identical other than the cams. They will drop right in. You probably won't even need to change the shims but it's good to have the kit just in case.
Man you folks are lucky!
Add me to the list of folks looking for a set of OEM E cams.
Ebay baby, $190 shipped, lightly used.
There is a Stage 1 hotcam/OE E cam combo on there now. The original Stage one not the new one, the one that is similar to the E cam.
https://www.ebay.com/itm/2002-Suzuki-DRZ400E-DRZ-400E-400-E-Stage-1-Hot-Cam-Camshaft-Intake-Exhaust-Set/122799377590?epid=1741305946&hash=item1c9769ccb6:g:UqwAAOSwX3FaA7kj&vxp=mtr
I found some older New Old Stock stage 1 hotcams FS as well (I would confirm they are the OG stage 1 before buying though).
Intake (2047-1IN).
https://www.ebay.com/itm/Hot-Cams-Camshaft-Suzuki-DRZ-400-2249-1IN/400924790749?epid=171130625&hash=item5d58facfdd:g:IY8AAOSwax5YoneI&vxp=mtr
https://www.ebay.com/itm/Hot-Cams-Stage-1-Intake-Camshaft-Suzuki-DRZ400E-DRZ400S-DRZ400SM-Arctic-Cat-DVX/112425406443?epid=171130625&hash=item1a2d138feb:i:112425406443&vxp=mtr
Exhaust (2048-1E).
https://www.ebay.com/itm/Hot-Cams-Stage-1-Exhaust-Cam-DRZ400-KFX400-KLX400-LTZ400-2048-1E-68-2021/253164874342?hash=item3af1cd6a66:g:LE0AAOSws-1Zizop&vxp=mtr
https://www.ebay.com/itm/Hot-Cams-Stage-1-Exhaust-Camshaft-Suzuki-DRZ400S-LTZ400-Z-DRZ400-DRZ400E-Arctic/291362841384?epid=171292033&hash=item43d6942328:g:jeEAAOSw~OVWz1yW&vxp=mtr
https://www.ebay.com/itm/KAWASAKI-KLX400-HOT-CAMS-CAM-STAGE-1-EXHAUST-KLX-400-2048-1E/290354325157?epid=171292033&hash=item439a7766a5:g:vx4AAOSwo4pYfjTk&vxp=mtr
*EDIT, removed last link, was not an "E" cam
Edited by MyKLX400
You don't really want to be used Scored cams :-)
Intake (2047-1IN).
Exhaust (2048-1E).
Used E intake cam
https://www.ebay.com/itm/2003-DRZ400-E-S-SM-KLX400-SR-INTAKE-CAM-SHAFT-ASSY-KAWASAKI-SUZUKI-2000-2014/171832353081?epid=1722959536&hash=item280201a139:g:HU4AAOSw9N1VhdXK&vxp=mtr
The 2nd link is for a current style Stage 1, it even gives the part number in the description. The last link (Klx400SR cam) is the same thing as a stock S/SM cam.
The previous stage 1 (2047) is the same thing as the current stage 2's minus the adjustable Sprocket. They are not the "OG" cams. They are actually referred to as New School Hot Cams​(NSHC). Pn 2003-1IN (Intake) and 2003-1E (exhaust) are the originals (OSHC).
The previous stage 1 (2047) is the same thing as the current stage 2's minus the adjustable Sprocket. They are not the "OG" cams. They are actually referred to as New School Hot Cams(NSHC). Pn 2003-1IN (Intake) and 2003-1E (exhaust) are the originals (OSHC).
Whoops, looks like rushing at work got me on a couple links.
The second link that list BOTH old and new numbers, my bad.
Last link is a "S" cam, I only saw the "E" pat. I have removed the link
____________________________________________________________
For future searching refference:
The older stage 1 hot cams are 2047-1IN and 2048-1E numbers (these are very close to stock "E"s).
The older stage 2 hot cams  are 2003-1in and 2003-1E numbers.
Just clarifying this so that anyone searching can find the correct info. BTW I got my info on the parts #'s from this thread.
Yes I am holding out for a set of OEM E cams. I am not looking for close or anything else, I have seen enough threads on here with timing questions and folks fiddling with a tooth forward and back that I would like to just keep it simple. It is interesting though that the E model is still made available in some countries but we can't get the cams from Suzuki. Makes you wonder what cams are really coming in the latest available E models in countries outside US.
Closer;
Pre 2006 the 2003IN was a 'Stage 1' mod. Adding the 2003EX was the 'Stage 2' mod. If you say, 'OSHC', folks will know you're referring to the 2003 series.
Works best to just call out the cam number, since HC has made at least eight different cams for the DRZ.
