ktm 350 oil presure spring
reading on ktm talk about oil pressure spring being out of spec and causing oil presure to drop cause engine failure. Anyone on hear heard of or had a problem with the spring out of spec. thinking of replacing for piece of mind.  thanks
The spring is the same as the 500, and supposed to be 25mm length.
post how long your is, when you check, don't lose the ball that falls out.
