IT'S LIVE! Full Review 2019 Honda CRF450L!!! Read more... ×
hondacr125mods how fast does a cr125 go stock and with mods such as reeds pipe and stuff
Simple bolt ons don’t do much to increase power with cr125 they are mostly used to fine tune the power.. depends what you’re useing it for. I️ have a cr125 track racebike that I️ love and is plenty fast when the engine is built right. If you’re using it for mainly trail riding don’t worry about how fast it goes. Worry about learning how to ride a 2-stroke in that good ole sweet power band
What year is it? The best upgrade I️ made on my cr125 was buying a new carb from JD Jetting. They send you one perfectly jetted for your altitude. All you have to do is make minor adjustment. It will make your engine so much more crisp and responsive. Bolt ons don’t hurt. Make sure you rebuild the top end first things. Without proper compression 125s run like poop
how much you think your cr can go and its 2001, things got a dinted pipe but replacing it
Honestly probably tops out at 65mph I️ have it geared higher for more toque for these tight SoCal tracks
Not about how fast it is but how fast it gets there:ride: that's what you want. I'll guarantee its fast enough on track for you. Twisting the throttle is better than any hop up remember that :thumbsup: goodluck
  • Like 2
