H4 LED Headlight Bulb Kit
Looking for info on an H4 LED bulb replacement. I'm not looking to use the 4x6 headlights many have used. I'll be doing the KLX450 headlight/fairing mod.
Looks like eBay has a bunch of options, but to use with stock DRZ wiring what wattage/specs am I looking for? Anyone had success/nightmares?
Looking at something like this:
https://www.ebay.com/itm/Universal-H4-6500K-COB-LED-Motorcycle-Hi-Lo-Fog-Lamp-Headlight-Bulb-For-Moto-RH/292243629220?hash=item440b13e4a4:g:mxwAAOSwJ~RZsOJ4&vxp=mtr
factory service manual says 12v 60/55 Watt
however, an LED is going to be rated way differently than a regular bulb..... And I tried a LED bulb on mine, it sucked!!!! worse than the stock light, but it had a pretty color to it ;)  ended up replacing mine with the 4x6
Edited by 74jimbo
My understanding of lights is bulb, reflector and lens need to be designed as a unit.  Just replacing an incandescent bulb with an LED doesn't  put the light source in the right focal position.
I may pick up the LED setup and give it a shot on the chance that even though they weren't designed together, they still work together. I'd only be out $15 if it didn't go right/could just return it after. They claim ~3000 lumens which I'd think would be plenty bright, so long as it's getting sufficient power. Looks like there are other units that include ballast, which could help with any issues there.
https://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html
This is what I run, was on the bike when j bought it. It's super bright. 3800 lumens. Looks like they also have the option for a 7000 lumen. Easy plug n play installation and has a nice heat sink and fan. Pulls less wattage than stock so it saves you power if you wanted to run other things like heated grips or aux lights
I think I would put my faith in Cyclops over $14 ebay bulb.
I'm gonna go the Cyclops route, I think. Headlight going out on an ADV ride is not something I wanna deal with.
I have an older 3800 cyclops from before they were doing the shields for the .
Search my name and you will find my posts on it, namely the wire mod for better beam that was posted on advrider by spiderman.
Also google for a discount code and order direct from cyclops
I got a LED 3800 lum from Pro Cycle two years ago, I am using the stock headlight assembly, It is super bright white light, ride almost everyday, in the rain if I have to, still working great. It has a little fan on the back of it and a little transformer box, direct plug in. Has high and low beam. Kinda expensive at $72.20171202_223558.jpg
here is a link the page with great info
Edited by MyKLX400
