is 2006 yz250 a good choice for enduro and MX
I have never ridden 2t dirt-bike , i start my dirt bike adventure this year with a 4t yz450 and i love this sport. now am interested to test 2t cross and want to use it for enduro and MX. are this bikes ( yz250) good for both enduro and MX use !? i heard that yz250 is the same from 2006 up to 2016 and have no change . what about honda cr250r !? which year and model of this two brand worth owning !?
It seems like the 2005-present YZ250's are the most popular and affordable mx/endure bikes for amateurs.  You can also make KX, CR, and RMs dual purpose as well, just research to make sure they have broad power bands.
I heard KX have the shortest power band compare to yz and cr
06 first year of SSS suspension, second year of aluminum frame. A rigid frame and bike best suited for MX.
Edited by 2 STOKE YZ DOC
  • Like 3
All the other Japanese 2 strokes are 10+ years old.
Yamaha still makes essentially the same bike as they did in 06. This means you can easily get OE parts, there are a ton of aftermarket parts and even a lot of used parts available.
Plus it is still an awesome all around bike.
  • Like 2
Thats an important factor . If you can get new OEM part rather than used one. I guess that in 2strock series yama ha is more reliable compare to other brands !? Or maybe i am wrong !?
I use a 05 YZ250 (with 06 SSS forks) for Enduro and it work well. There are plenty of aftermarket "Enduro" parts for the YZ250, large gas tank, flywheel weight, skid plate, radiator guards.... The best and cheapest thing I did to the YZ for Enduro was install a Suzuki needle in the carb. NECJ and retarded the timing.
Suzuki needle part number 13383-37FE0 $11.54  setting the timing is free!
Good Luck!
  • Like 2
Good Luck!
Tanx and hope you are enjoying your YZ ;)
I ride an enduro series and some harescrambles with my 06 yz250. It is an extremely versatile machine.
  • Like 4
your bike look awesome .
6 minutes ago, aminem said:
found this video on you tube .. absolutely gorgeous
Nice color scheme.
Better get a case saver on that thing before the ride. Very expensive mistake to not run one.
20 minutes ago, 2 STOKE YZ DOC said:
Nice color scheme.
hope he dose :D
I use my 06 for enduro and trail riding and only hit a mx track once or twice a year.
I have suspension work(I'm heavy and need to do this to every bike made), a flywheel weight, hand guards, a big tank and a skid plate for mods, other than the flywheel weight my motors 100% stock and I like it just fine.
  • Like 2
seems interesting that many riders use yz250 2t for enduro . my first thought was that : 250 2t can have so much power that rider avoiding them .
Put a 13oz FWW, and Rekluse on it and it becomes a tractor.
I think of 2 strokes as bipolar, at low rpm off the pipe they lug and are hard to stall but at high rpm they rip and go like hell. This makes them both easy to ride and fast, it just depends on how much you rev it up.
The 2 stroke mx bikes from the 80's and 90's gave 2 strokes a bad name as they were hard hitting hard to ride on/off switches, the 2000 and up ones are pretty easy to ride for the most part.
good . any adjustment to power valve !?
i heard it as well , maybe thats why many rider prefer 4 strokes insted of 2t . mx 250 2t are beast that are not easy for everyone to handle .
  • Similar Content
    • By wpp1000
      Whenever I start my ttr230 I have to have no choke, or very little. If It has some choke even when cold it will rev up a small bit then die off. What could the cause be? I have the 38 and 130 jets in it. does this mean it is running lean or rich, or something completely different. The bike still runs perfectly it just takes a little bit to get it started.
    • By photonicreno
      Hi all!
       I've got an issue, one of many when it comes to bikes. I searched throughout all the pages I could find pertaining to my situation and couldn't find very much useful information.
      So the issue is, the bike has no electric start.... until it's hot enough to melt steel that is. It will bump start first time every time. But I can sit and crank the starter over for ever and it'll never start until the charger is bumped up past 200 amps. Not good.
       The story so far,
      Got the bike for 1k cash. Guy said it has no spark and no second gear. This particular guy also only ever rode newer crotch rockets. Brought it home pulled the choke, attached battery charger and she fired right up. Ran like absolute crap, but oh well I figure it's an older bike with only 10k miles so it probably needs a good carb cleaning. Took the carb apart and didn't know I messed something up until way later(didn't tighten down main jet). Oh well she runs well enough if I can get her started. Moved from California to Oklahoma. Eventually found the money to fix 2nd gear, and as I am a certified Honda small engine technician apprentice I figured it would be no big deal. Completely tore down engine to it's roots replaced 2nd, and 5th gear(because 5th gear connects to 2nd on the countershaft) dogs were worn pretty badly on both. The engine looked quite good compared to most others I've seen. Put the engine back together as per the service manual. Did all the right steps including loosening the banjo bolts to test for proper oil pressure. I even tore apart the electric starter to clean the contacts and the brushes and replace the dielectric grease. Adjusted the valves as per the service manual, replaced all gaskets, o-rings, seals, and oil filter.
       Finally after about a month of waiting on parts and reassembly I get to start her, only she doesn't. Electric start is still giving me the same issues I've always had. So I replaced the Ignition coil, CDI box, and put a new battery in, plus the starter motor rebuild. Nothing. Still cranks forever. I said what the heck and tried to push it slightly down hill and bump start it, and voila... fired right up! Once she gets hot enough and the stator charges the battery enough it'll electric start... sometimes.
       So I looked towards ignition, used a tool called ignition mate. Pretty awesome tool if you can afford it. Well while cranking the ignition mate reads the spark plug is getting 1-4kw of "spark" every cycle, well it only fires after getting up past 5kw sometimes 6-8kw. And sometimes the ignition would be intermittent as in it wouldn't give any spark at all. I cycle the ignition and it seems to soft reset the bike as it will usually give it back spark. I tested this with the new and old CDI box, the old one would never spark. Ever. So I threw it in the trash. A month later I stil l can't figure it out.
       Is there something I'm missing?
      TL;DR
      Bike won't start using electric start only bump start before and after engine rebuild
      Electric start works after pushing the starter past about 200 cold cranking amps or when hot.
    • By GreenMT_Rider
      30 years ago I sold my beloved 1985 CR500. I was young and needed money for a car. I had a lot of fun on that bike and some of the best dirt bike memories were made on it. Out of all the bikes I've owned it's the only one I regret selling. I've had opportunities to buy a 85 cr500 before but never pulled the trigger figuring leave the fond memories in the past. Well today I couldn't pass up the bike any longer. I found me a nice project bike to take up some free winter time. The bike is all there and it runs but most importantly it was cheap. Not the prettiest but it's mine. With lots of money and time it shall be returned to it's former glory and be ready to make some new memories.
    • By Ktm520sxrider
      Ready to seal back up
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
