Starting issues
Hi all,
i could use some of your ideas. I’ve had to let my 2000 wr400 sit about about a year and a half, due to work issues. Now I’m back and trying to get it started!
I know the usual starting procedure. Problems seems to be sticky valves, ( I can sometimes kick it past compression) and it will only fire sometimes with the hot start open. It will run for a second or two before dying. I have taken the carb out, cleaned the float chamber and jets, and checked it all out. Spark plug is sparking ok. I know some but not much.
Any more ideas? Can’t wait to get back on board!
Thanks, Pete
Sounds like a plugged pilot jet. They are hard to clean. Buy a new one.
Thanks Steve, any clues how I tell which jet it is??
The pilot jet looks like this.
