02 KTM 250 gasket help needed
Hi guys thanks in advance. Now that i have finally tracked down the correct riggt side cover gasket, i am running into q couple of new issues.
1. There is a black plastic fitting with o ring that seals the base of the power valve cover to the right engine side cover. It is touching the mating surface of the right side case half so i cant get the right side cover gasket on without tearing it up. The forum wont allow me to upload a pic wth... So, do i need to remove the top end in order to get full access to the case half surface that mates with the right side cover?
2. The previous mechanic appears to have bent the power valve rod...or is it supposed to have a slight bend?20171115_152753.jpg20171115_152808.jpg
