Wheel hub for what?
The garbage?
Buit seriously, that hub looks like hell, the spokes all corroded. I be the nipples are all frozen and rim from what I can see, not so good. In ay case, what are the dimensions stamped in the rim? That might narrow it down (small bike, big bike). I'd also guess it was a dual sport as that white plastic looks like a speedo drive on the Disk side (another hint). Any numbers or anything on the hub?
58 minutes ago, William1 said:The garbage?
Yep it definitely looks bad but I got a brand new tire for 30 bucks so I don't really mind. That's a 21" front tire
30 minutes ago, jackstrap said:Yep it definitely looks bad but I got a brand new tire for 30 bucks so I don't really mind. That's a 21" front tire
Got you, hopefully the tire was not too old and 'hard'.
So it is a 21" rim, what is the width of the rim (not tire)? 1.85?
Looks like a 1.85 to me
But for the tire it doesn't seem too old it's been mounted on a bike wheel but sure is it's got less
Than 5 hours of use anyway for 30 bucks I think it's worth to give a try on my cr250 also that's a front tire it should have less stress on it than the rear one.
13 minutes ago, jackstrap said:But for the tire it doesn't seem too old it's been mounted on a bike wheel but sure is it's got less
Tires have a date code.
That's a 2016 tire.
Sure looks like a front hub for a RMX250
I think they quit putting the plastic cover on them around 1996 so it would be from an 89 to 95 RMX
34 minutes ago, mxwiz said:Sure looks like a front hub for a RMX250
I think you could be onto something there. this ones off a 94 rmx250
should have 05D00 stamped on it somewhere if it is stamped
that cap was used on rmx250 89-96 + also used on rm125 & 250 89-95
speedo drive is opposite side
Is it worth anything or do I make a clock with it and hang it on the wall?
I bought a tire yesterday and the guy who had the tire before gave me this wheel. However, I can't find what that wheel hub is going on any idea?
