Is this bad? cam lobes worn?
So i just got a 2012 kx450f i take it apart to check the valves and they are all too loose and the cams look like this. should i just re shim and go ride? This is my first four stroke and first time dealing with this stuff the bike seems to run fine. Any help would be greatly appreciated.
They will zero out over time...is it hard to start?
An if the gap is to big you need to add a thicker shim to bring then closer to what the spec is on them
