Need help with fuel leak
I have a pretty good fuel leak from this brass piece.  I checked to see if it was the float...but I don't think it is.  I emptied the bowl and let everything drain.  Then when i turn the fuel back on it leaks immediately from the brass fitting here.  Doesn't appear it is leaking from the hose end, but the end closest to the carb itself.  I am just not sure how to replace this since it just rotates around freely.  Do I just unscrew the crew that is shown right by it?  That screw appears stripped so if I can get it off I will need another one of those as well.  Also what is the brass part called?
Thanks
Hello, what you need is the packing kit, which I believe is #2.There are 3 o rings on this brass piece and a screw who's head can be seen in the photo is just behind it, remove the screw and fuel line and pull out on this part.To remove the rings use a pick type tool to remove or break them then install the new o rings, don't sweat trying to get the first o ring to the bottom just fit it into the top groove and then the others will slide right over. It probable would not hurt to order up a new genuine fuel line and the proper stock clips for it,Hope this helps.
Yep, you'll need the gasket kit which includes those o-rings and the screw. So, # 2 & # 23.  You can try needle nose vice grips to remove the screw or, if that doesn't work, put a cut off wheel on a Dremel and cut a straight slot in the screw and use an impact driver.
Edited by HRC27
One more thing, yes, you remove that screw and the fitting will pull out.
Edited by HRC27
Unless that screw is stripped beyond all belief the impact driver shown here will get it out. I have this same exact tool and it works beautifully when used properly. And the best part is that it is an inexpensive tool to purchase. I have a pricey Snap-On that I would not bother with if needed because this tool works better. Set the direction for counter-clockwise extraction, Bear down on the screw with the tool in one hand and then tap the top of the tool with a hammer. I have found for me a small 3lb hammer like this works best.
https://www.homedepot.com/p/Ludell-3-lb-Drilling-Hammer-with-10-5-in-American-Hickory-handle-11203/204326568?cm_mmc=Shopping|THD|G|0|G-BASE-PLA-D25T-HandTools|&gclid=CjwKCAiA9MTQBRAREiwAzmytw_XuNPfIhneafxNEWwumjmnujHL58dkIxRwUK0XPyRsHrsbM35AYWxoCz7IQAvD_BwE&gclsrc=aw.ds&dclid=CNmJovSAzNcCFQ98YgodTFIINA
Thanks everyone for all the help.  I do have an impact driver I can use.  I will try that first.
Also I attached the another picture....Is the screw that I "circled" #39 in the parts list?  That one is also stripped, so I might as well get one of those as well.
Yes, # 39 or you can just go to Ace Hardware and get a stainless allen* head (less likely to strip) & washer.  Don't over tighten that one and you won't have problems with it down the road.
* 4mm x 0.70 (thread)  x 14 (length)
Edited by HRC27
When you get a new fuel line, consider getting a couple clamps from a CRF250X (pic is of a 2012 X).  Much easier to install and they have more "clamp" to them.
Thanks for all the help.  One last question....do you believe that I will be able to find #23 at a hardware store as well?  I was able to get the gasket kit locally.  The other parts I can wait on, but I need to get #23 by this weekend.
Yes, for sure.  Again, get a stainless allen headed bolt/screw.  Just take it in with you, find a nut that fits it and that's your size/thread, find the bolts that size then match the length.
Edited by HRC27
Thanks Robert for all your help.  I got it all fixed up and ready to go.  Appreciate it.  Now I can go ride this weekend.
My pleasure man. :thumbsup:
