Now that I am rebuilding my 2001 DRZ400S due to a crash.. I want to be sure that when it happens again the bike will not be completely totaled.  I cannot find any axle sliders for it because it does not have hollow axles. The only thing I have been able to find are engine guards that mount to the frame so I will for sure be getting those. So I just have questions on how to get axle sliders mounted on my bike, and I also will probably be getting a handbrake sometime in the near future. Would I be better off just swapping to an SM swingarm?
I wish there was a document listing all the spec differences between the SM and S models.
Any help would be great.
Edited by Supermotofool
Tags
Could drill out the axles.  SM swing arm needs an SM caliper arm, keep the S swing arm it's less hassel.
I'd bet you can just get the SM axle and put it right in the S swingarm . The diameter is the same otherwise swapping wheels wouldn't be possible . Length difference may be all there is but something tells me that wouldn't be an issue either. A washer added to bother ends may work if the SM axle is longer (I'm guessing it is if they're different).
Or swap to a SM swingarm and get the nicer looking adjuster.
Or drill & tap the S axle
Edited by jjktmrider
