1994 kx125
Hi everyone, I have a 1994 kx125 I need to know if the seat from a 1998 kx125 will work.
more than likely a seat from a 94 kx125 will work on a 94 kx125.
I meant to say the seat from a 1998 kx125 will work on a 1994 kx125 wooops
There I fixed it lol
Edit... Same part numbers.
Edited by DEMI
same part number... 53001/A
So it will work?
Same part number, so I would think so. Just looked them up for you on motosport.com
You can verify however.
Edited by DEMI
Thanks so much man that's great
no problem, glad to help.
IT'S NOT THE SAME PART NUMBER!!!
THINK!! How can two seats with different graphics have the same part number?!!
You are looking at the reference number, not the part number.
OP, you need to hold off until someone else comments.
I don't know what to think now
I just checked on motosport..... care to elaborate???????  guess microfiches are wrong.
Edited by DEMI
Kdx is right, too bad the message came across as a dick.
Lol, well I guess I'll have to keep looking, how do you look up those part numbers
ask KDX, he knows.... or could have done what I just did.
What website did you go to?
If you think I acted like a dick, wait until he got a part that won't work based on your suggestion. Then you can worry.
www.kawasaki.com for parts diagrams.
www.partzilla.com to not only see the part numbers, but also see which other models came with that exact part number. In your case, the seat may have the same base and work, but it won't have the same part number due to the different seat cover.
Reference numbers are 12345. Part numbers are 12345-6789.
Edited by KDXGarage
Thanks, do you know which seats are compatible?
Nope. I think that something changed on the base. You may want to check around to see if that is the case.
Ok thanks for the help, appreciate it
