• Announcements
    • Bryan Bosch
      JUST IN!   04/24/2018
      HOW TO: 4-STROKE PISTON REPLACEMENT DONE RIGHT!
GlennRay
DR-350SE Lightening
10 posts in this topic
I would like to reduce the weight of my DR-350SE and the only ways that come to mind are 1) Replace the battery with a Lithium Ion battery.  2) Replace the stock exhaust system with an aftermarket system.  3) Replace the stock gas tank with a plastic tank.  I don't think that any one of these changes will result in a significant loss of weight, but they are the only places I can see to reduce the weight of the bike.  Any thoughts on this subject will be appreciated!
You could take off the passenger pegs, if you haven't already.  With their brackets, they're fairly heavy.
1 person likes this
the steel brake light and turn signal assembly could be replaced with something much lighter. could also replace the front and rear fenders with lighter/more modern assemblies. a bunch of steel parts can be replace with aluminum (see the above linked thread). titanium footrests would be lower and give more foot room. replace steel bolts with aluminium or titanium bolts. tonnes of stuff you can do, depends on desired cost/benefit ratio
I took them off.  My highly accurate(?) bathroom scales say that I weigh 155.7 lbs with out the passenger pegs and 158.7 lbs with them.  So three pounds lost right there!
Thanks!
I had the front forks off the other day to correct the oil level and I weighed the components while I had them off.  Left fork leg, 10.5 lbs.  Right fork leg, 10.5 lbs.  Front wheel/tire, 19.4 lbs.
So learn to wheelie really well and you've lost 40.4 lbs!
1 person likes this
I guess I should get a Uni-cycle and start practicing!
