Mavric_Bass
Standard sprocket sizes on DR350se?
7 posts in this topic
Anyone know the standard tooth count of DR350se front and rear sprocket?
I bought a DiD standard sprocket and chain kit but the ratio is way too close at a 110kph the engine is nearing valve float.
I expected it to be closer as I put 17” sumo rim on the back and 110/90-17 tyre
Currently the sprockets are 14 front and 42 rear
Any info on sprocket combinations that others are using would be appreciated
Cheers
if yours is non-cush you can get a 39t & 15t front
Cheers plugeye yeah mine is not a cush drive so was hopeful for a smaller rear sprocket seeing as I am running a 17” rear. Hopefully I can source one in NZ
What brand is yours? Might look online if I can’t one
