Eduardo Guerra
i need help with this old dirt bike
9 posts in this topic
i cant figure out what model is this dirt bike it would be greatly appreciates if someone could help me the owner supposedly told me its a suzuki 1999 but didnt know what model
i need this help because, i want to buy that dirt bike so i can restore it and make it run good
vin number is:  Jsldk41a7x2100079
If seller doesnt know what it is, then chances are it wont have a title, which you should be wary of, though a couple of states dont need them i believe
1 person likes this
Donate that beauty to Ronnie Mac, he'll think he hit the dirt bike lottery and be on 7th heaven!!
  • Similar Content
    • By Markl5557
      Morning ,
        I am looking for recommended radiator guards for my 2017 drz400 I was looking into the devol metal ones . Any one have suggested brands? Replies are always appreciated !
    • By Ted Lukecart
      Parting out a 98 KX250.  NOTE: bike is not complete so if you ask about "price for all" it will be based on each part and only a 10% discount plus freight shipping.
      Parts List:
      2- Engine cases with new bearings installed (right & left) $350
      1- Case gasket set (new) $25
      1- Crank w/rod (new unused) $150
      1- Transmission gear set $100
      1- Set of shift forks $50
      1- Shift drum $25
      1- Kick start input shaft/gear/spring $25
      1- Clutch disk set $75
      1- Clutch basket $50
      1- Clutch pressure plate $25
      1- Clutch lever and input shaft $15
      1- Fly wheel $50
      1- Stator w/wiring $100
      1- Wiring harness $50
      1- Coil w/wire $25
      1- re-plated cylinder (New unused plating)(NO power valve assembly) $350
      1- Top end gasket set (new unopened) $25
      1- power valve assembly $75
      1- Piston/rings/wrist pin (New in box) $85
      1- Cylinder head $50
      1- Kick starter $15
      1- Shifter $115
      1- Clutch cover $25
      1- Power valve cover $15
      1- Fly wheel cover $25
      1- Carburetor (assembled) $100
      1- FMF Gnarly pipe (plated)(no dents) $150
      1- FMF Power Core muffler $75
      1- air box (stock) $50
      2- Radiators w/cap $150
      1- Fuel tank (standard MX size) $100
      2- Forks (stock) $250
      1- Shock w/linkage (stock) $100
      1- Swing arm $75
      1- Frame w/pegs $150
      1- sub-frame $75
      1- Triple clamp $100
      1- Renthal handle bar w/mounts $50
      1- Hand throttle assembly w/cable $50
      1- Skid plate (aluminum)(no dents) $75
      1- Front brake caliper $50
      1- Front brake lever assembly w/hose $25
      1- Rear brake lever $15
      1- Rear brake slave cylinder w/hose $25
      1- Rear brake caliper $50
      1- Clutch lever assembly w/cable $25
      1- Front wheel w/brake disk (no tire or tube) $50
      1- Rear wheel with brake disk (no tire, tube or sprocket) $50
      1- Front fender (new unused black) $25
      1- Seat w/good aftermarket cover (black & green) $25
      All prices include shipping To Washington, Oregon, Idaho, Montana.  Outside the Northwest I will add additional shipping cost based on your address.
      Call or text for pictures
    • By Simon Davis
      So heres the issue, i have replaced the seals multiple times for the water pump however still get a leak out of the weep hole. Over time it goes into the oil side. I think ive found the issue but dont know how to fix it. There is grooves on the ‘water pump shaft’. To which most would say replace it, its not as easy as that, the shaft is directly connected to the crankshaft so my question is, can i fix these grooves without replacing the crankshaft and thus spliting the case?
    • By grantsafari
      I have a 2015 ktm 250sx with pro circuit exhaust with the r304 silencer. I'm looking for a new exhaust system that is best for desert, track, and mostly just freeriding. Let me know what you think is best.
    • By Eduardo Guerra
      this is my 1999 dirt bike that i just bought and it runs but i want to know what hose goes in there and where is it going to be atattched too?
      the red wires where do they go connected too and the black hose from the engine please help me i will keep you guys updated, i want to make this a good project. Thanks
