DR650 Adventure Bike Build
by RMATV
if you own a DR650 you'll understand.
I don't have the big tank or luggage on mine but I did do all the suspension,carb and GSXR exhaust so far.
What about jetting and the air box mod?  Definitely some improvements to be had there.
Suspension wise I personally have only changed the fork springs and set the suspension on "factory low".  But I also did the GSXR muffler, FCR carb, air box, and one size smaller on the front sprocket.  It's amazing at how much faster it accelerates with those mods.
I have done the airbox mod and jetting from Motolab,I had an FCR I rebuilt and modified but decided against it and sold it,still on the stock gearing due to some freeway travel on my commute.I have LED lights on it too but I might change them up with the spots and the LED headlamp instead of the bulb I currently have.
Hmmmm,
Cool looking YZ fender, cool looking Safari faring, cool looking aluminum panniers and running the stock suspension valving...
Send your  damper  rods  to Bruces  suspension . I had upgraded  front springs   (.55).The forks were still horrible  off road.The modified  rods  made the forks  much  better . Only cost about   $80.
I have a spare  set of drz400e  49 mm showa  forks  that I was going  to  swap.Not necessary  after Bruces  mods to stock fork .
Not familiar with Bruce's Suspension.  Then again I'm not going to do anything too crazy with my DR, at the same time, will the 49mm Showa's directly bolt on?
No,they  don't  directly  bolt on.I am not positive , but believe  that  the  dr650  stem may  need  to  be  pressed into  the  drz400e  tripple  clamps . Then a bracket  needs  to  be  fabricated  to relocate  the front  brake  caliper  to accommodate  the larger diameter  rotor  of the dr650  wheel.
Cant go wrong  with  Bruces  modified  rods .
