98 cr 125 weird noise from new rebuild
My top end went on m 98 cr 125, the needle bearing clip came out and broke apart and shrapnel got everywhere and blew it up. I cleaned out the top end and washed out the crank with the bike upside down. the bike starts up great and seems to run fine but im getting a weird di-di-di-di-di-di-di noise coming from the motor. i tried adjust the power valve and tightening everything but the noise is still there. Here is a link to a video where you can hear the sound. It gets louder as rpm's get higher and at really low rpm barely idling it goes away. I am pretty new to bikes and 2 strokes so any help would be appreciated.
https://youtu.be/msfU8WCXg8E
Edited by deanmellor
Sounds pretty normal to me bud
I've had 2. They always sound like that.
That sounds like a healthy 2-stroke to me.
If it is a wiseco piston or a forged piston they will knock like that until they heat up. (Like 4 min) don’t ride until fully heated up also while letting it heat up don’t let it stay at 1 rpm but don’t go over 1/2 throttle
yeah its a wiseco pro lite. thank you that helps me a lot
Yea than that your problem I have 02 cr125 same thing happened after I switched to wiseco forged piston they last long just make sure to let the warm up or you will have a cold seizure and lick up your topend
*lock up
HMU with any other problems with the bike I’m like a cr125 guru I took apart and rebuilt my bike from scratch just HMU and I’ll be glad to help with any problems
sweet man perfect thanks a lot for the help and i probably will
NP
If your talking about the clatter noise, its normal... For future refs, install the c-clips with the opening either up or down, never or back.
Sounds good, warm her up and let her rip.. good luck.
Wow thanks,
I've always been worried about a similar knocking I hear coming from my top end when I am warming up my '95 yz 125 - that also has a wiseco piston in it.
Good to hear its nothing bad!
Wow thanks,
No problem
I have a 98 rm250 and it sound the same. The bike has never been blown up or damaged.
