520 EXC keeps burning headlight
My 520exc keeps blowing out my headlight withe the time being anywhere from 30 seconds to 10 mins. I've also noticed that if I go over big bumps or do a wheelie it'll blow right on impact. I'm just using H3 bulbs from the auto store and have tried 3 different brands. Also something that could be related is my battery that doesn't charge well (could be a bad battery). I'm thinking it could be the stator but don't know what to test.
Measure voltage across your headlight terminals if its over 12-14 volts or jumps up in voltage when you rev the motor then the Regulator/Rectifier is toast
  • Like 3
would that even matter as the current going to the headlight is A/C? I thought the current came straight from the stator. Regardless, it does read around 11/12v at idle and jumps to over 15 at higher rpms.
8 hours ago, Max Bakerman said:
.... and jumps to over 15 at higher rpms.
You should also check the health of your battery due to possible over-charging
My old WR450 did the same thing....I replaced the voltage regulator/rectifier...problem solved.
Just ordered one. Thanks people
This issue is usually the result of a "dirty" supply voltage. If your bulb has a bad earth (ground connection) it can cause it or - as people have previously mentioned - your rectifier is not supplying a good steady voltage.
Check the ground wire first.... it's cheaper than a rectifier ;)
