Fitting a 2015/16 fender and head light to a 2014?
I purchased a 2015 plastic kit for my 2014 bike, I think the fender needs a bracket (although I can't find one?) but I am wondering if I can fit the 15 front fender and head light without much work? I haven't got a 15 headlight to see the difference has anyone done it before?
You need to fab a bracket or get 15/16 triples . I have read about conversion brackets but never seen one. The 15/16 fender has two bolts to the front of the triples. The headlight pins into the fender.
Edited by S10gto
The only difference between the 15/16 triples and the 14 is the mount for the front fender and then the light requires the newer front fender right? Does the 14 light work with the 15 fender?
Correct. Not sure about the mask though. The 14 mask is multi piece. The 15/16 is one piece. If you go to RM ATV click on OEM parts and you can see the many difference.
Hope this helps.
