OEM replacement Brake pads or other Company?
Time to change brake pads on my daughters 2017 KX 100. Do you suggest replace with OEM or go with company like Galfer, Renthal, or moto-masters?
Oem .
Go with whichever you like, but I would stay away from the cheap end of aftermarket. EBC used to be some really great aftermarket pads and shoes. Dunlop Pad if they still make them. I had not heard that Galfer made pads. Moto Masters sounds like a cheap one?? Not sure on that one.
I've been using the cheapest aftermarket stuff I can get, under ten bucks a set delivered.  Got them on my KX's, my Yamaha 600, they work fine.  They take a bit to bed in and really bite if your rotors are worn, and the stock pads don't seem to be kind to rotors so yours are probably worn to some extent.
I ride almost all dry conditions.  If you are running through wet, soupy mud your experience may vary.
Edited by turbo dan
I like OEM best but, like turbo dan, I have been running some really cheap organic pads that work really well.
  • Similar Content
    • By LoganV
      I recently ordered some new front brake pads for my yz450f 2010. The new pads were ebc's and overall were very similar to the oem pads on the bike already. The only difference was they did not have a notch on the side that is not the hole side. In order to get them to fit I had to remove the metal clip in the back of the brake housing. Does anyone know if this is okay? So far they seem to be fine.
      I'm very new to dirt bikes.
      Thanks for any advice!
