2012 Cranky to start questions
I know some of the CRF250s are cranky or difficult to start and it depends on the years.  My 2012 takes 20-30 kicks to start on a cold day (40 degrees F or less) and even 10 on a nice day when the machine is cold.  I read the FAQs and did the following as part of my winter maintenance and was hoping to improve my starting:
NEW Twin Air filter right out of the bag pre-oiled
NEW spark plug
Adjusted valve lash to .005 intake, .009 exhaust
Cleaned the coil, wire and connections thoroughly.
This is an EFI engine and I do not understand why it would be finicky. No amount of throttle twisting is going to do anything since these do not have an accel pump.
After this maintenance I have exactly the same problem! My starting procedure cold - pull out fast idle knob, slow kick 3-4 times to prime fuel pump, get kick lever back to TDC, kick reasonable speed (not a fast kick like a two stroke).  I have read all sorts of non-sense about blip the throttle three times, hold it open a smidge etc. Just seems like this is masking a problem that could be addressed or they are old wives tails.
Once it fires you are good to do - settles down and idles great on fast idle for 30-60 seconds push in knob.  Runs like an animal I love this thing.  Just a beast to start.
I did not do the de-compression mod that seems to be an '06-'08 era mod but maybe I am incorrect.
Hard to start 4-stroke issues are more often than not valve or fuel related.
Your valve lash may be within specs but:
-how many times have they been re-shimmed?  (how many engine hours,cylinder head ever been serviced ?)
Despite having proper lash, the sealing surfaces (valve face and valve seats) may be worn and allowing compression to escape while cranking.
A leakdown test would give you an indication if so.
-do the timing marks relative position show any sign of chain stretch?
-has the fuel injector ever been cleaned?  Pump pressure verified etc.
Many suggest pre-filtering the fuel BEFORE filling a FI bike's tank.
Edited by mlatour
I do not know how many hours are the engine but the bike had relatively little use.  When I shimmed it I think it was the first time and it was only out by .001.  The shims did not have any marking on them making me think they were original.  I would like to do a leak down test that would be interesting.  Timing marks looked perfectly level in line with the head when the dot was lined up with the pointer in the cranks case.
I have never cleaned the injector and I suspect no one ever has.  Is there a procedure for this?  Wouldn't a dirty injector or weak fuel pump show other symptoms while I was riding it?  It has killed throttle response and runs amazing.
I am going to look at the pre-filters that seam like a no brainer since the fuel cans always seem to have something in them.
Sorry can't help you with any injector related maintenance tips, never tinkered with any FI bikes.
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
    • By Throttlejockey
      Please post pics only. All other posts will be deleted so it doesn't get out of hand. PM the poster for more info or create a post.
      Violators will get a one day ban from the forum.
    • By bull413
      I checked the valve clearance on my 06 crf250r and both exhaust valves is at .007 and the intake is (left side) .005 and (right side) .000??? idk my feeler gague only went down to .002 and it would not slide in.
      Is that ok for the exhaust? Do I need to just shim the right side on the intake? or does both need shimming?
