Tmx carb on RM144?
I am in the process of rebuilding an 01 RM125, having EG do the 144 kit ported for low end and putting on the fmf fatty/ shorty combo. When taking everything apart u noticed the slide on the stock mikuni 36mm TM was dinged up pretty bad. A new oem slide is $120 but I found a new 35mm TMX flat slide carb for about $145 so I would rather just replace the whole thing if it went cause any problems. Does anyone have any experience with running the newer tmx carbs on a 125 or 144? Is there anything I should be aware of before doing the swap?
