2016 KX250f Starting problems
Ok guys I need someone smarter than I to help me figure this out.  I have a 2016 KX250f and starting this thing is like asking for a snow ball fight in hell!!!!  Kicking it over is not the problem, I've read and tried the whole slowly kicking it over 3-4 times finding TDC and then kick is nice and solid.  I have checked the valve clearances and they are all good, new spark plug, tried the whole turning the high idle screw to xxx amount of turns in or out.....NOTHING ! I love KX bikes and have had them most my life but this one is trying my patients.  I've also switched out the green,black and white cuplers to see if this would make a difference and its still sucks to start. Ive hooked up and checked to see if any codes are thrown and they are all good.  I can bump start it pushing it down the road and it runs fine.  after it is warm it will kick over and start if I give it a little throttle when kicking.  Any help on this would be awesome.
If valve clearances are good, I suggest looking at the problem from the fuel delivery side. Perhaps dirty injectors or fuel pump. Also, how many hours on the bike? When was the last time top end done?
Not exactly sure on hrs, had original tires in really good shape so I'm guessing not a lot. Is there something to run through your fuel to clean the injectors?
You shouldn't have to give it any throttle when starting it, warm or cold. I would check those valve clearances before trying to troubleshoot the fuel system.
Valve clearences are on spec , new plug, air filter is clean, getting good spark
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
